DDNS on RUT200 restarts frequently
Hi
I have a RUT200 with RUT2M_R_00.07.13.4 firmware where the DDNS service restarts quite often. Only once, the router have managed to update the WAN IP to Cloudflare, but that was on the RUT2M_R_00.07.14.2 firmware.
I had to roll back to 07.13.4 because my VPN setup stoped working.
This is from the system log:
659 Thu May 15 20:38:28 2025 user.notice ddns-scripts[26850]: Cloudflare: pid 26850 terminated by sigterm at 2025-05-15 20:38
660 Thu May 15 20:38:35 2025 user.notice ddns-scripts[27630]: Cloudflare: pid 27630 started at 2025-05-15 20:38
661 Thu May 15 20:38:38 2025 user.notice ddns-scripts[27234]: Cloudflare: pid 27234 terminated by sigterm at 2025-05-15 20:38
662 Thu May 15 20:38:44 2025 user.notice ddns-scripts[28017]: Cloudflare: pid 28017 started at 2025-05-15 20:38
663 Thu May 15 20:38:48 2025 user.notice ddns-scripts[27630]: Cloudflare: pid 27630 terminated by sigterm at 2025-05-15 20:38
664 Thu May 15 20:38:54 2025 user.notice ddns-scripts[28404]: Cloudflare: pid 28404 started at 2025-05-15 20:38
665 Thu May 15 20:38:58 2025 daemon.info ipsec: 11[IKE] <VPN_IPs|23> unable to resolve %any, initiate aborted
666 Thu May 15 20:38:58 2025 user.notice ddns-scripts[28017]: Cloudflare: pid 28017 terminated by sigterm at 2025-05-15 20:38
667 Thu May 15 20:39:04 2025 user.notice ddns-scripts[28796]: Cloudflare: pid 28796 started at 2025-05-15 20:39
668 Thu May 15 20:39:08 2025 user.notice ddns-scripts[28404]: Cloudflare: pid 28404 terminated by sigterm at 2025-05-15 20:39
669 Thu May 15 20:39:15 2025 user.notice ddns-scripts[29186]: Cloudflare: pid 29186 started at 2025-05-15 20:39
670 Thu May 15 20:39:20 2025 user.notice ddns-scripts[28796]: Cloudflare: pid 28796 terminated by sigterm at 2025-05-15 20:39
Any ideas what this can be?
To assist you further, I’d need the full troubleshooting logs (or rather, the entire troubleshoot file) - if you still have it, I’ve sent you a form to fill out, the Ticket ID should be the thread number, which is 13794.
Once you fill out the form, I’ll reach out to you via email and we’ll continue our conversation from there.
