'Data To Server' - setup via command line
Is it possible to setup the ‘data to server’ from command line?
Replicating the configuration via the GUI is too cumbersome on many devices and i cannot use backup/restore functionalities as I have cannot overwrite unique parameters. (e.g. openvpn files).
Looking forward to your advices
Yes, it is quite easy to set this up via the command line. I recommend first configuring your desired settings through the WebUI. Then, access the router via SSH/CLI and copy the Data to Server configuration from this file: /etc/config/data_sender. Then you can use this as you want and paste to multiple devices easily. The configuration should look like this:
