Hello. So my system uses a RUT956 that reads data from a device using modbus. The issue I have is that if a modbus request fails the router would instead send the next register in it’s place. For example if I have register 1,2,3,4,5 that I want to read and register 3 fails then the router would send register 1,2,4,5 but it would send it as if it was register 1,2,3,4 meaning that the data I received for register 3 and 4 are incorrect. I hope that helps explain my issue. Thanks in advance for any help.
@ChrishLuies Hello,
Apologies for the delayed response!
This feature is not available on Teltonika Networks devices. However, if a missing register does not cause any issues in your setup, you might consider configuring separate Modbus requests for each one. When using the “Data to Server” service to send Modbus data, only the successfully collected data is transmitted.
Hope this helps!
