Data Acquisition based on the Ignition.
Hi Team,
Can we get the data acquisition based on the Ignition?
Like, when the Ignition is on, data should be sent at a frequency of 10 seconds; when the ignition is off, data should be sent in every 5 minutes.
Please note that if we use the movement source to Ignition, the Idle time will be affected. We don’t want that.
Hi Mohit,
Good day, Thank you for reaching out to Teltonika Telematics Community Forum!
Sadly the data acquisition modes are based on movement sources.
But you can try the settings below.
The ignition source should be DIN 1, DIN 1 should be connected to the ignition cable of the vehicle so that when you turn the ignition on the mode will automatically change from stop to moving
The movement source should be the ignition
From the Data acquisition set the frequency according to your requirements.
Because you do not want the idle time to be affected maybe you can enable the instant movement for movement detection, Instant movement has no delay so once movement is detected the value will become 1.
Please note if the solution above didn’t help you, you may contact your sales manager for POC,
If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it. Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with a description of your situation to info@teltonika.lt
Maynard C.
