Customisation of teltonika devices
Hi. We are currently testing teltonika device to replace our old devices for our clients fleet
Total size of fleet is 135 to150
Currently we are facing difficulties in teltonika devices which are not matching our requirements,so is it possible to customise firmware as per requirement?
  1. accident reconstruction like second by second data cannot be read or extracted from device which in very essential for our clients to check the genuineness of the violations triggered, also if incase of accident sec to sec data required
  2. we prefer Rpm as ignition source,but if we use it then immobilizer doesn’t work as digi out is dependent on ignition source, so if driver unable to start the engine how rpm can be read
    Our requirements is driver flashes i button ,driver validated or registered then he can start engine,then ignition is detected (trip start)
    3 speeding event is generated instantly but we like to have minimum speeding duration before event triggers( current other devices has this function)
    4)i button doesn’t read programmed ID’s for example driver id is 45780 it doesn’t read in teltonika ( as in teltonika it should be converted to hexa decimal which is a hectic task because driver changes regularly and uses same i buttons which are programmed accordingly
All above mentioned features are available in current device which we are using , supplier is scope technologies m hub 828
Since we cannot get new devices from them we are looking for global supplier like teltonika
Hi Karthik,
Good day, Thank you for reaching out to Teltonika Telematics Community Forum!
For the firmware development request or any customization kindly please contact your sales manager.
If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it. Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with a description of your situation to info@teltonika
Maynard C.
