I recently purchased the RUT300 IoT router, and I’m looking to implement some custom functionality. I was wondering if anyone could help clarify whether the RUT300 supports custom programming for the following use case:
- MQTT Integration: I need the router to connect to a custom MQTT broker and subscribe to a specific topic. Once data is received on that topic, it should trigger an action.
- TCP Commands: Based on the data received from MQTT, I need the router to send specific TCP commands to a connected device through one of the LAN ports.
Does anyone know if this is possible on the RUT300? If so, are there any APIs or programming guides available to help set this up?
