Create Alert WAN IP
I’m try to create an alert for change WAN IP but i didn’t find the correct settings.
Is someone how knows the correct settings?
If you are using RMS there is Alerts and Automations sections where you can make an alert when your WAN IP changes.
You should navigate to Management>Alerts & Automations.
Monitoring templates- Dynamic monitoring
Choose parameter -Wan IP
Value - your WAN IP address
Actions - choose send email ( if you wanna get notification via email)
Please keep in mind that this alert will only trigger when that particular IP address changes, and notifications will be sent based on the time interval you have configured.
To configure the time interval, simply navigate to Management → Devices, then click on your device to access the settings.
Then click on Actions and Manage monitoring templates.
Please select the monitoring period that best suits your needs — this determines how frequently the alert will check for any changes. Please keep in mind that the shorter the interval you choose (for example, every 5 minutes), the more data will be consumed.
If you require more advanced monitoring, you are always welcome to set up a custom alert that better suits your needs.
Žilvinas.
