Control RUT241 I/O Output via CLI / Remote API while using the Device
I am working with a Teltonika RUT241 and I would like to remotely control the device’s I/O output (turn it ON/OFF) using CLI commands. My use case is the following:
  • The RUT241 will be configured as an OpenVPN client.
  • When needed, I want to remotely trigger the output of the available I/O ports.
  • I need a way to:
    • change/control the output state (ON/OFF),
    • retrieve the current state as feedback.
I am looking for guidance or examples on how to achieve this using:
  • CLI commands, and/or
  • HTTPS / REST API / RPC calls
    to control and monitor the I/O state.
Specifically, I’d appreciate help with:
  • Correct CLI commands or scripts to control I/O output.
  • Whether the built-in API can toggle and read I/O states.
Any recommended secure approach to combine this with OpenVPN for remote access.
If anyone has experience or documentation pointers regarding this setup, that would be very helpful.
Thank you!
Greetings, @mlogothetis,
This functionality can be achieved using both CLI commands and API calls.
Using CLI commands
To check the current output status, you can use the following command:
ubus call ioman.gpio.dout1 status
If the returned value is 0, the pin is low; if the value is 1, the pin is high.
For more information, please refer to this article:
To change the output state, use the following command:
ubus call ioman.gpio.dout1 set '{"value":"1"}'
Using API calls
First, you need to obtain a session-based authentication token by executing the following API call:
curl -k -X POST https://<router_ip>/api/login \
  -H "Content-Type: application/json" \
  -d '{"username":"root","password":"<password>"}'
The response will include a session token, which is then used automatically via cookies or headers.
To read the digital output state, use the following API call:
curl -k https://<router_ip>/api/io/dout1/status
The response should look similar to this:
  "value": "0",
  "direction": "out"
To change the output state, you can use the following API calls:
Turn ON
curl -k -X POST https://<router_ip>/api/io/dout1/actions/set \
  -d '{"value":"1"}'
Turn OFF
  -d '{"value":"0"}'
For detailed API documentation and available endpoints, please refer to the following link:
Please note that writing custom scripts is outside the scope of our technical support.
If you have any additional questions, feel free to let me know.
Warm regards,
