I have problem with my connection, i tried 2 different sims and both antennas are connected
When the module cannot connect to the operator through the normal sequence or there are restrictions on the SIM card itself, it may connect to emergency services (similar to how phones can call emergency services without a connection to an operator).
To troubleshoot:
- Test the SIM card in another device, such as a phone, to verify if it can connect to the operator normally.
- Ensure that the SIM card is active and has an appropriate data plan.
- Try setting a custom APN. In the WebUI, navigate to Network → WAN and click Edit next to the mobile interface.
- Check the signal strength (this can be found in Status → Network → Mobile).
Hello, i have checked all of them. Also, i restore to default settings and i backed up it again, but it doesnt work
Is the SIM card working with other devices, such as a phone?
