i have a RutX10 and i want connect to one dispositive bluetooth. i can to read in this forum that, teorically i can connect any dispositive bluetooth allways that this dispositive will be BLE 4.0 compatible. I have tryed to connect my samsung earpods like example to try this and the dispositive in theory are paring but i cant see any data, for example the batery. My question is. Is really possible connect any dispositive bluetooth to RUTX10 for obtain datas?. Is possible that in my before example i do it any wrong?.
It is correct that our device has a bluetooth module, and receive and send data via bluetooth.
However in your instance, from how i understood the query, the router would not implement the BT audio profile - essentially a session-level protocol - to make the headphones work, or route the data via the router. So in theory it is possible, however in practice it may not be. We have not tested the device in such circumstances.
I understand that you said, my objetive is not recive the audio stream, only recive data for example: the battery, o any stat. I have connected to mijia xiaomi higrometer, and in this case, after do the paring i recive data, but for i have readed in other sites, is necesary obtain acces to other data, because with the command blesem only i got access to basic information and only recive the follow parameters:
