Connecting Speed limiter function to Fuel Pump
Hello , i would like to connect FMC130 speed limiting function to fuel pump using a relay and need assistance with the wiring. So far i have wired Pin 30 to +12v , Pin 85 to Dout 1 from FMC130 and 87a to fuel pump (+)cable and Pin 86 to Ignition?
Please assist with the correct wiring. Thank you to those that will assist.
Hello @duxx,
Good day! We have a wiki page created for the implementation of FMC130 with speed limiting functionality. I recommend you to browse through the page for more information about the connecting and configuration on the device.
FMC130 Speed Limit: Speed Limiting Solution FMC130+ETC - Wiki Knowledge Base | Teltonika GPS
I hope this helps.
Patrick S.
Thank you @Patrick_Sangalang
