Connect to RUTX 11 together
I’m building an autonomous radio-controlled Boat for measurement purposes. For the connection, I have two RUTX11 available. The Routers should be connected with WLAN. Is it possible to use one Router like a Repeater? The Network Ports on both Routers have to work. Is it possible to do this? And how? I don’t have any experience.
Best Regards
Simon
Hi @SimonPe05,
as you already can see noone is willing to help you because of your totally unclear questions.
  1. “the routers should be connected vie WLAN”
  • do you have an existing wireless network where you want the two routers to connect to?
  • or do you want one of the routers to act as an access point the the other one as a client?
  • and then - what would you need a repeater for?
  1. “the network ports on both routers have to work”
  • yes, they usually do unless you configure something stupid
  1. “I don’t have any experience”
  • then get some - coming here and saying “I don’t knwo what I want but please help me” is the wrong approach
So, please post a diagram of what you want to achieve and there might be help.
[btw you are writing in English, so nouns usually don’t start with an uppercase letter]
Timelapse Admin
