Buenos días,
Necesitamos ayuda para poder configurar el gateway RUTX11 con sensores de temperatura. Qué programa necesitamos exactamente para poder configurar el gateway?
Buenos días,
I kindly ask you to use English on the community forum. This ensures everyone can understand your query and allows us to assist you more effectively.
If I understood correctly, you want to connect a sensor to the RUTX11 device. For this, I recommend checking the following resources:
