Config file with default SSID
Is it possible to create a default configuration file for the RUT241 that can be utilized to configure other new RUT241 devices, while ensuring that each individual RUT241 retains its default SSID?
Good afternoon,
You can create a backup file for the RUT241 : https://wiki.teltonika-networks.com/view/RUT241_Configuration_Backup
And then if another RUT241 is of the same firmware, and same product code, that backup can be uploaded on it to be utilized.
Any settings that you do not need to transfer, you would need to change in the config folder in the backup file.
Arturas
Delete from backup achieve /config/wireless file.
