Communication between PLC's & Ethernet devices
Hello Everyone,
I am interested to install PLCs at several sites, they are located at specific distance between each other and there is no infrastructure that enables us to connect via copper / fiber.
There is one Master PLC that should forward a signal to all other PLCs.
I need to make all these devices communicate each other like they are connected to the same LAN network.
What are ths possible ways using Teltonika ?
Note :
It’s possible to have static ip addresses for the SIM cards, if it helps here.
Thanks in advance !
Shouldn’t be a problem.
  • get SIM cards with staic public IPs
  • get RUT240/RUT241s (thats what we use, about 55 of them)
  • create port forwardings with the correponding IP addresses
You’re done.
Timelapse Admin
PS: can’t you just use a WLAN?
