Combo MIMO antenna PR1KCL25 with two TRB140
Hi, Is is possible to share a Combo MIMO antenna, like the PR1KCL25, with two TRB140 routers?
While the TRBs would most likely work with this antenna, the antenna itself is designed for MIMO operation (MAIN and AUX) with different gain for each antenna. TRB140 utilizes SISO setup, so I’d suggest using an antenna PR1AS420 or PR1KS210.
Third party options can also be used. More information on what to look out for can be found here: Third-party Antennas - Teltonika Networks Wiki
Are there any SISO antennas designed to be used for SISO devices. I need to simplify the mounting of a product because we don’t have enough space for two external antennas.
Thanks for you fast response.
We do not have any antennas in our portfolio that would be verified for such a use case, but in theory, any 2x2 MIMO antenna will work, however, it might not perform as well as two seperate SISO antennas.
