Change the monitoring server
Good afternoon
Teltonika FMB130.
The task is to change the monitoring server.
After accepting the settings, the transfer to the new server works for 2-3 days, after which the settings are reset to the old values.
Attempts to change were through the setparam and flush sms-commands
Good day, are you using the latest firmware for FMB130?
Did you send the commands below to change the server settings?
setparam 2004:(domain/IP address);2005(Port);2006:(0-TCP , 1 UDP )
You should receive a confirmation from the device that the parameters are already changed, after you received that confirmation send cpureset to restart the device.
To confirm that the parameters already changed please send getparam commands: FMB getparam - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
To download the latest firmware for FMB130 please click here: https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.27.14.Rev.00_and_configurator.zip
Maynard C.
