Hi I triedt to set up an vpn via zerotier.
I watched the Teltonika YT video How to Set Up ZeroTier Communication Bridge on RUTX50 & RUTX11 (youtube.com) see 4:46…
In Network, General Settings, LAN , I change the physical setting from192.168.1.1 to 192.168.1.2 and the DHCP Server to disable as advised in the video…
Now I can not reach the router anymore… what can I do?
Thx for your help
Tom
You need to set a static IP address as DHCP does not lease the IP address anymore.
You will need to set it to something like 192.168.1.27 and then access it to 192.168.1.2
https://wiki.teltonika-networks.com/view/Setting_up_a_Static_IP_address_on_a_Ubuntu_16.04_PC
br
thx worked
