Change M-Bus settings via MQTT
Hey everyone, is it possible to change the m-bus settings via mqtt? e.g. due slaveId or the polling interval?
Changing the M-Bus configuration on the TRB143 device via MQTT is not possible at the moment. If this is a hard requirement, I would recommend contacting your sales manager (if there’s one) in order to assist you further since this will fall into a custom development process.
Contact us: Teltonika Networks - LTE Routers, Gateways & Modems for IoT
Rob
