Certificate generation and signing Bug
Firmware version RUTX_R_00.07.05.4
Firmware build date 2023-11-07 15:54:54
Internal modem firmware version EG06ELAR04A08M4G|
Kernel version 5.10.188
i think I found a bug in the certificate generation System->Administration->Certificates
How the error can be detected
In the Certificates Manager tab the server and client generated CSRs are listed in the certificate request section instead of their certificates in the certificates section, although certificates have been generated.
Reproduction of error
  1. Generate Root CA → self sign it → two files are generated in /etc/certificates and info file in /etc/certifictaes/status is updaetd correctly
  2. Generate Sub CA → sign it with Root CA → two files are generated in /etc/certificates and info file in /etc/certifictaes/status is updaetd correctly
  3. Generate a server (or client) certificate → sign it with Sub CA → two files are generated in /etc/certificates BUT info file is updates with type: req instead of type:cert although generated files are cert files
Delete CSR always checked in creation and signing process!!!
Equilibrium
Hello Equilibrium
Would you kindly try to refer this for your case scenario and try to reach us if any issue occurs
https://wiki.teltonika-networks.com/view/Removing_of_HTTPS_security_warning
This has a detailed instruction on certificate creation
Shahl
