Cell lock on RUTX50
This product already has a band lock capability via the GUI. However there is also a cell lock capability via command line via gsmctl modem command. However this also requires a custom script such that cell lock is persistent across reboots, based on answers to other topics I have read here.
Please consider adding cell lock ability on the GUI to make this easier as this is a useful feature that many of us I guess will need at some point. I was thinking something like a scanner for neighboring cells and the ability to select the detected cells/bands just like we can now select just the bands. Essentially a graphical equivalent of the following commands:
gsmctl -A ‘AT+QENG=“NEIGHBOURCELL”’
gsmctl -A ‘AT+QNWLOCK=“4g/lte”,x,EARFCN,PCI’
Only reboot persistent.
Please share your thoughts.
Thank you for your suggestion. While the option to lock cells is available via the CLI, we are not planning to include it in the WebUI due to the nature of the command and its functionality.
We appreciate your understanding.
Thank you for your reply,
Understood.
Is there anything else I can assist you with?
No I’m fine on this topic. I think it can be closed.
