I’m operating on the RUT 240 device. FOTA is enabled and discover an update from RUT2_R_00.07.04.3 to RUT2_R_00.07.04.4. I can download the update through interface and apply for upgrading however, when trying to run rut_fota --fw_info command through SSH, I always get a [get_tap_info:135] error: Failed to load ‘device_management’ package error. Tried to search opkg repository for “device_management” and “device management” but there isn’t any such package. Is it a known problem and need to be addressed or did I miss something? I couldn’t find much about firmware updates or fota in the wiki.
root@RUT240:~# rut_fota --help
Usage: rut_fota [options]
Options:
-i, --fw_info retrieve information about available firmware downloads
-f, --download_fw download suggested device firmware
-n, --download_modem download suggested modem firmware
-p, --notify_server notify server after modem firmware download
-k, --upgrade_fw_keep upgrade firmware with keep settings after download
-u, --upgrade_fw upgrade firmware without keep settings after download
-s, --stable download stable firmware
-d, --debug enable debug mode
-h, --help show usage information
root@RUT240:~# rut_fota --fw_info
[get_tap_info:135] error: Failed to load 'device_management' package
root@RUT240:~# rut_fota -d --fw_info
Starting communication with FOTA server
Connected to rut.teltonika.lt:5000
Connected with SSL
Sending buffer of size 248
Decoded fw_info length=17 and value=|RUT2_R_00.07.04.4 |
Decoded fw_size length=8 and value=|11207640 |
Decoded wiki length=1 and value=|� |
Decoded date length=19 and value=|2023-07-04 05:40:56 |
Decoded modem_id length=3 and value=|1-1 |
Decoded modem_ver length=31 and value=|EC25ECGAR06A04M1G_01.004.01.004 |
Decoded modem_size length=1 and value=|� |
Decoded modem length=1 and value=|� |
Decoded fw_stable_info length=1 and value=|� |
value[0]=� (-1) fixed - set to 0
Decoded fw_stable_size length=1 and value=|� |
Decoded stable_wiki length=1 and value=|� |
Decoded stable_date length=1 and value=|� |
Communication successful
I’d like to create a simple shell script and use the existing cron job for searching for updates and to be informed about them in the way I choose in the script.
