I have RUTM50 (FW: RUTM_R_00.07.08) connected to an Allen Bradley PLC and a Windows 10 machine which I try to acces through RMS VPN hub.
They are all accessible through the local LAN if the RUTM50 (PING and HTTPS) but NOT when I connect through the VPN hub. The hub is up and working. I have tried to delete the hub and make a new one just to se if the problem was in the hub (US - Virginia). I also factory reset the RUTM50.
The routes are setup according to the image below.
The sessions user ip are setup according to the image below.
I can ping and reach the WebUI of the RUTM50 from the VPN.
I tried to trace the route to both devices.
I can ping the PLC and Windows 10 machine from the RUTM50 Diagnostics tool.
Yes both devices connected to the LAN of the RUTM50 have the gateway address configured 192.168.1.1
Does anyone have any idea where I could have made a mistake in the configuration?
