CAN'T PUBLISH ANALOG PORT DATA USING MQTT TO A BROKER IN AZURE Event Grid Namespace
I can’t send data from RUT955 to MQTT Broker over Azure Event Grid Namespace, I create a broker server and Tested it out using MQTTX and was able to communicate between Publisher and Subscriber, now my question is… How can I set up the Publisher part in Router if I do have RUT9_R_00.07.05.4 firmware version. I tried reading some old stuff about using MODBUS but this updated firmware doesn’t have those options any longer. I tried installing MQTT package by following this article steps: RUT955 MQTT - Teltonika Networks Wiki. So far I just can read there may be a connection from publisher on the server, but no data receive. What am I doing wrong? I have done some steps for Analog Read also Data to Server Selecting MQTT and MQTT publisher. By the way, I need to sent data periodically
