Cant enable monitoring after turning it off on my RUT955
On my RUT955, I turned off the monitoring and then wanted to enable it.
I turned it back on from RMS but it never came back.
Then I logged into the local portal and went to System → Cloud Solutions → RMS. I clicked on reconnect and got a fail in the Connecting field.
I have plenty of credits, and other devices are able to use monitoring.
I have network connectivity to your server
I have the latest firmware.
I see this when i login via ssh
Your JFFS2-partition seems full and overlays is mounted read-only
Please try to remove files from /overlay/upper/... and reboot!
There was a failed install of python so a cert could not get written.
Mon Apr  1 21:59:12 2024 daemon.err rms_mqtt[5368]: [apply_auth_certs:117] error: Unable to write certificate '/etc/rms_mqtt/ca.crt'
Fixing my own problems is great. Hope anyone else can make use of my wasted time.
