I have a RUT955 on the latest firmware. I did a factory reset and everything seems to work fine apart from it’s not connecting to the RMS system.
If I login to RMS web portal the Latest Connection Attempts field is just full of retries so it’s obviously getting thru to RMS, it’s just not accepting the login?
|LATEST EVENT|TIME|
|Device has attempted to connect to the system.|2023-08-17 15:36:37|
|Device has attempted to connect to the system.|2023-08-17 15:34:23|
|Device has attempted to connect to the system.|2023-08-17 15:32:08|
|Device has attempted to connect to the system.|2023-08-17 15:29:56|
|Device has attempted to connect to the system.|2023-08-17 15:27:44|
Do I need to reset something on RMS or the device?
Since this is a public forum, I can’t check on your device in particular to see what could be causing the issue. I’d recommend unregistering and re-adding it to RMS, as that could help mitigate the issue.
If that does not help, please fill out the Contact Us form here: Teltonika Networks - LTE Routers, Gateways & Modems for IoT and we will be able to help you.
Great to hear that!
If you experience any further issues, please contact us directly by filling out the Contact Us form as mentioned in the previous comment.
