Hello. I setup a new RUT955 last week. The default setup went fine, and I was able to activate both sims for internet access. I then changed the default password and added another SSID. Both SSIDs worked fine.
Because I needed a specific sensor to connect to the RUT955, I changed the default 192.168.1.x address range to: 172.16.244.1 (and 255.255.255.0, DNS: 8.8.8.8, DHCP enabled with range 172.16.244.132-172.16.244.249)
The system was rebooted and I used WiFi to get to the webui on 172.16.244.1. The UI opened, but, as I tried logging in the UI kept spinning and not letting me in, no matter how long I waited. After several resets no change. I then did a “factory reset” (holding reset while powering on for 12-15 sec). Results:
- Default WiFi is available (but no internet)
- The UI no longer appears (not responding)
- I can ping the 172.16.244.1 IP address from either a LAN connection or connected to the default Wifi
How would I get control back again? I’ve tried SSH using LAN port (ssh admin@172.16.244.1) but the passwords (original and new) are not accepted. But I’m not sure if that’s the RUT955 or my PC responding. What else can be done to revive the router?
