Hello!
I cannot ping between two devices connected to the wifi, where the client isolation is off and i cannot ping the devices in wifi with the RUT and connectet to the LAN as well, but i can ping the Gateway
Thank you for your input!
Hello!
I added some any rules for lan, and rebooted the device, but no diffrence.
There is alot of config time for vpn guest wifi, reporting etc so i would not like to reset the device.
Heres the logs:
troubleshoot-RUTM10-2024-10-15.tar.gz (296.9 KB)
I added an any rule for lan, but still no connection:
Hi madadmin,
I have tried to do the same set up of yours locally and both are pinging each other. Can you try to disable firewall for both end devices. With default configuration on my router, I can ping between two devices connected via Wi-Fi.
