Cannot create VPN client connection
Hello, I’m not able to create VPN client connection. If I use the same credentials / settings in windows the everything is ok.
Fri Nov 17 13:34:31 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 5675. Destroying anyway.
Fri Nov 17 13:34:40 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 34401, Remote: 0
Fri Nov 17 13:34:40 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:34:40 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:34:51 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 57487. Destroying anyway.
Fri Nov 17 13:35:00 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 13952, Remote: 0
Fri Nov 17 13:35:00 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:35:01 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:35:11 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 34401. Destroying anyway.
Fri Nov 17 13:35:21 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 24902, Remote: 0
Fri Nov 17 13:35:21 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:35:21 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:35:31 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 13952. Destroying anyway.
Fri Nov 17 13:35:41 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 26495, Remote: 0
Fri Nov 17 13:35:41 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:35:41 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:35:52 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 24902. Destroying anyway.
Fri Nov 17 13:36:01 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 40661, Remote: 0
Fri Nov 17 13:36:01 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:36:01 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:36:12 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 26495. Destroying anyway.
Fri Nov 17 13:36:21 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 20560, Remote: 0
Fri Nov 17 13:36:21 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:36:22 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:36:32 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 40661. Destroying anyway.
Fri Nov 17 13:36:42 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 7031, Remote: 0
Fri Nov 17 13:36:42 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:36:42 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:36:52 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 20560. Destroying anyway.
Fri Nov 17 13:37:02 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 42237, Remote: 0
Fri Nov 17 13:37:02 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:37:02 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:37:13 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 7031. Destroying anyway.
Fri Nov 17 13:37:22 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 40890, Remote: 0
Fri Nov 17 13:37:22 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:37:22 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:37:33 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 42237. Destroying anyway.
Fri Nov 17 13:37:42 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 29740, Remote: 0
Fri Nov 17 13:37:42 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:37:43 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:37:53 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 40890. Destroying anyway.
Fri Nov 17 13:38:03 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 62035, Remote: 0
Fri Nov 17 13:38:03 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:38:03 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:38:13 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 29740. Destroying anyway.
Fri Nov 17 13:38:23 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 53043, Remote: 0
Fri Nov 17 13:38:23 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:38:23 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:38:34 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 62035. Destroying anyway.
Fri Nov 17 13:38:43 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 33135, Remote: 0
Fri Nov 17 13:38:43 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:38:43 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:38:54 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 53043. Destroying anyway.
Fri Nov 17 13:39:03 2023 daemon.info xl2tpd[2049]: Disconnecting from 156.17.xxx.yyy, Local: 18266, Remote: 0
Fri Nov 17 13:39:03 2023 daemon.info xl2tpd[2049]: Connection 0 closed to 156.17.xxx.yyy, port 1701 (Goodbye!)
Fri Nov 17 13:39:04 2023 daemon.notice xl2tpd[2049]: Connecting to host 156.17.xxx.yyy, port 1701
Fri Nov 17 13:39:14 2023 daemon.debug xl2tpd[2049]: Unable to deliver closing message for tunnel 33135. Destroying anyway.
