CANbus interface via Ethernet RUT956
Looking at the possibility of connecting a CANbus-Ethernet module via Ethernet port of RUT956 router. Any suggestions/guidance please ?
Hello Champ
The Teltonika routers will not be supporting the CANbus protocol, as far as i have seen
But with some port forward options I think you should be able to use the router as a gateway with the appropriate software to read the CANbus data
Thank you for your response.
