There is a physical eSIM card such as sysmoEUICC1-C2G, so can I use a RUT361 for provisioning eSIM profiles using device’s either WebUI or console?
Good afternoon,
Physical eSIM cards such as the sysmoEUICC1-C2G are designed to provide eSIM capabilities for devices lacking native eUICC support by acting as a physical SIM form-factor card containing an eUICC chip.
In your case, I would recommend obtaining a device with eSIM functionality, as we have several in our portfolio. RUT241 eSIM, RUTM52, RUTM54, RUTM56, OTD500.
If you go to our device product page, f.e. : RUT241 industrial 4G eSIM™ router
Scroll a bit, and go to ordering section, you can find product codes for the devices. Make sure the one you are getting, has a eSIM option mentioned underneath.
For devices with a custom product code that support eSIM, please contact us by filling out the Contact Us form available at: Teltonika Networks - LTE Routers, Gateways & Modems for IoT
Arturas
All set. Thanks.
