Can and how to reset (counted) values in FMB140
Hi all,
I need to reset two values in FMB140(lv-can) (device is updated to newest firmware and lvcan via fota)
io105 - Total mileage (counted)
io107 - Fuel Consumed (counted)
i was trying to do it via SMS
lvcanclear 1 and lvcanclear 2
and got answer “LVCAN Not connected!”(i was trying to do so with ignition on and of same result)
Is there a way to rest those values, or way to do so with usb connection or other way than sms command?
Hello @Asiu,
I hope you are doing well. Were you able to update the device to the latest Firmware version?
Kindly refer on this link for more information: Firmware versions - Teltonika Telematics Wiki
Once done, kindly try to send again the SMS command as mentioned below.
“lvcanclear #”
Possible # values:
0 – Engine work time (counted);
1 – Fuel Consumed (counted);
2 – Vehicle Mileage (counted).
Patrick S.
