Calyx on moving vehicles
Hi Guys!
Wanted to ask it is ideal to use the Calyx for Drones / Rovers / Vehicles or any other moving platforms?
Is it suitable for it? if anyone here has some insights regarding to this topic i would like to hear you out :slight_smile:
Thanks!
While the Calyx is electronically suitable, it is not ideal mechanically because it doesnโ€™t have certifications for vibration, shock, or automotive use.
Because it lacks these mechanical standards, plugging the dongle directly into a moving platform poses a risk of disconnection or port damage due to movement. However, if you could dampen the vibrations with an enclosure or some other solution, it should work properly.
