Bug with port forwarding?
I want to use port forwarding from VPN (OpenVPN) to LAN.
All devices in LAN use the same port.
When I setup the forwarding rules, I can reach only the second device.
When I setup this from WAN to LAN it works as expected.
I use RUTX11 with firmware RUTX_R_00.07.06.3
Uwe
The rules look fine.
Are you able to reach your RUTX11 over OpenVPN?
Have you checked if the traffic is forwarded from RUTX11 to those devices? You can use tcpdump from SSH/CLI (username ‘root’):
opkg update
opkg install tcpdump
tcpdump -i any port 10000
Yes, I can reach RUTX11 via the OpenVPN tunnel:
I can also reach a LAN device through the tunnel!
I can reach the second LAN device directly from RUTX11.
Uwe
