[Bug] RUTX11 RUTX_R_00.07.05.4 Update Breaks Mullvad OpenVPN
According to official docs here it’s necessary to create a file for authentication at: /etc/openvpn/mullvad_client.auth. Unfortunately after the update, the file is no longer there and VPN fails.
Fri Nov 24 09:34:19 2023 daemon.err openvpn(mv_se)[7166]: Error opening 'Auth' auth file: /etc/openvpn/mullvad_client.auth: No such file or directory (errno=2)
Fri Nov 24 09:34:19 2023 daemon.notice openvpn(mv_se)[7166]: Exiting due to fatal error
This is now the second time in a row, that an update breaks OpenVPN.
Is there a better way to report bugs, than on this forum?
If you’re adding your own files and want to ensure they persist when you update the device, you can include the file in the /etc/sysupgrade.conf file.
Good to know, thank you very much!
