Good morning,
We have RUT200 routers before we had the RUT240 model.
With the RUT200 we cannot set up bridges to have the WAN port and the LAN port identical. Do you know if there is a problem? we updated the latest firmware.
Regards
Good morning,
Regards
Teltonika has changed configuration with the latest firmware RutOS 7.5.
Please check out and follow my topic - I have had same case same problem.
You need to change settings in order to work LAN as WAN.
See below:
Robert.
