Best Configurator settings for FMM003 to maximize OBD2/IO data collection with high-frequency logging
We have recently purchased the Teltonika FMM003 OBD tracker for a fleet telemetry research project in South Korea. We are testing it on various Korean vehicles (both Internal Combustion Engine (ICE) and Electric Vehicles (EV)).
Although the FMM003 supports a wide range of OBD2 and I/O parameters, we are currently receiving very limited data during our tests. Since we are in the early R&D phase, our primary goal is to gather as much data as possible (regardless of whether the values are active/valid or not for a specific vehicle) so we can analyze what is available.
Additionally, to detect transient states like regenerative braking in EVs (which might not expose direct pedal states on standard OBD2), we want to implement a high-frequency data acquisition setup:
- Logging/Data gathering interval: 1 second
- Server sending interval (via LTE): 1 minute
We would highly appreciate your guidance on how to configure the I/O and OBD2 tabs in the Teltonika Configurator to achieve this safely without overloading the device.
Specifically, we have the following questions:
1. Priority Settings:
If we want to collect all available parameters in every record, should we set the Priority of all targets to “Low”? If we set them to “High” or “Panic”, we assume it will cause immediate GPRS connections for every tiny change, leading to network overload, battery drain, and buffer overflow. Is this correct?
2. Event Only:
To ensure we receive all data points at every single log interval (without missing fields when values don’t change), should we set “Event Only” to “No” for all parameters?
3. Operand & Averaging Constant:
Is it correct to keep the Operand as “Monitoring”? Also, for highly dynamic values like pedal positions or speed to detect regenerative braking, should we set the “Averaging Constant” to “1” to avoid any delay or filtering?
4. Low Level / High Level:
For simple periodic monitoring (where we don’t need threshold-based alarms), should we just leave the “Low Level” and “High Level” values at “0” (default)?
5. Data Acquisition Frequency:
Is the device stable enough to handle a 1-second record generation (Min Period = 1s or 1000ms) and a 1-minute server upload (Send Period = 60s)?
Are there any hardware limitations (such as RAM buffer limits, flash memory writes, or CAN bus load) we should be aware of when logging dozens of OBD2 parameters at a 1-second interval? What are the best-practice limits for the minimum period on the FMM003?
6. Obtaining OEM/Custom OBD2 Data for Korean Vehicles:
Since standard OBD2 PIDs on Hyundai/Kia ICEs and EVs are quite limited, does the FMM003 support reading OEM CAN/OBD parameters for Korean vehicles? If so, do we need to configure Custom OBD PIDs, or is there a specific database/firmware we should use?
Thank you in advance for your support. As we are new to Teltonika hardware, your detailed guide will be extremely helpful for our project.
Best regards
Good Day,
Apologies for the delayed response to your queries.
Priority Settings
The difference between Low, High, and Panic priority is related to how records are generated and sent.
If a parameter is set to Low Priority, it will be included and sent according to the configured record sending period. For example, if the record sending period is set to 10 seconds, the parameter will be recorded and sent every 10 seconds.
For High or Panic priority, if the operand is set to Monitoring, the parameter will still be sent according to the configured sending period. However, if the operand is set to On Change, On Entrance, On Exit, etc., then an event record will be generated as soon as the configured condition is met. In this case, the record will be sent to the server with the relevant Event ID, indicating that this parameter triggered the event.
For more details, please refer to the wiki link below:
FMM003 I/O settings - Teltonika Telematics Wiki
Event Only
The Event Only option should be set to No if you want the parameter to be included in every record.
Operand
Yes, the operand should be set to Monitoring if you want the parameter to be included in every regular record.
Avg Const
If the Avg Const value is set to 10, the new value must be present for approximately 1 second before the device registers the change. Internal sampling is performed every 40 ms, meaning around 25 samples are taken per second.
For a more detailed explanation, please refer to the following wiki page:
Low Level and High Level Values
Yes, the Low Level and High Level values are used with operands such as On Entrance, On Exit, and similar threshold-based conditions.
1-Second Record Generation
The device can generate records every 1 second. However, since the device requires acknowledgement from the server, this may cause packet delays or queueing, especially if the server response is delayed or network conditions are not stable.
For this reason, I would recommend keeping the data acquisition and sending interval at around 10 seconds.
OBD OEM Parameters
Yes, the FMM003 can read OBD OEM parameters. Once the device is connected to the vehicle, it reads the VIN and downloads the relevant OBD OEM file from FOTA WEB.
For EV configuration, please ensure the following settings are used:
  • Ignition source: Accelerometer
  • Accelerometer start delay: 5–7 seconds
  • Accelerometer stop delay: 60 seconds
  • OBD Mode: Non-OBD Compliant
FMM003 OBD II settings - Teltonika Telematics Wiki
Regarding firmware, please use the latest firmware version available on the wiki, currently 04.02.00.Rev.602:
Firmware versions - Teltonika Telematics Wiki
Thanks, and best regards,
Imran S.
