BAT120: How to exit sleep mode?
received today an new bat120. my power led blinking very 5s. regarding the wiki it is indicating that the sleep mode is active…
also while charging the leds are blinking…
how can i end the sleep mode.
also the OUTPWR led needs 10-15s to turn on after connecting a device to the output
is this 5s blinking a normal behaviour or is it an doa device?
Make sure the ON/OFF switch is set to ON position.
What is the LED behavior when both IN PWR and OUT PWR cables are connected with the load? Does ON/OFF switch change the behavior of LEDs?
==> IN PWR: on; OUT PWR: on
==> all 4 Power LEDs continuously blinking 4s off / 1s on
when is switch off: alle leds are off
In the quickstart video, after switching on the bat120, the leds are turning on in a seqeunce and stay on showing the soc…
It could be that the battery of BAT120 is fully drained. Does the BAT120 supply power to a connected device without the IN PWR cable connected?
If it does not, please plug in the IN PWR cable, unplug any load, and leave it overnight to charge. If the behavior does not change, the device should most likely be returned to the seller for RMA.
