If you have one SIM card, it doesnt metter which slot you use. They can both work.
You are confused. There is no antenna per SIM card. Both antennas are used by internal modem whether you use one SIM card or two.
Nothing. Put your SIM card in, turn on the device, and you are done. If you put your SIM card in slot2, make sure you select it during setup wizard. Simple as that.
Thank you, i found a thin sign on the board how to put the card in. in this case the router software displays “no card insert” in both tried slots. Now i ordered some antanna external, we are here in a pour mobile region. But normaly i think it must detect the sim card and display in the web browser something like low signal … ?!?
