Hello, I found another problem with my Teltonika ATC700 tracker (previous reports: stops sending after queued commands, setparam response lost, movement does not turn on GNSS (cannot put third link
)). While the device sleeps, it periodically sets its clock back to the timestamp of the retained position, so records get timestamps hours or days in the past.
Setup
Device: ATC700 (Hw:ATC700 Mod:21), FW 3.20.0-rc.1+7.exp.autonomous, modem FW EG915UEUABR03A01M08_01.215.01.215
Configuration: Asset movement mode Movement (12150:1), Online Sleep (102:3), records every 3600 s when stopped, Send period 0, 107:0 (but the same happens also with 107:2 and with records every 300 s).
Problem
I left the device at home near the window for almost tow days. Then I looked in Traccar logs and obtained device dump/logs using the TCT.
The device falls asleep with a GNSS fix. GPSD_PWU_CTRL then turns on GNSS every hour and gets a fix (PWU fix captured, holding). When it goes back to sleep, the GNSS source changes to Retained and the time sync uses the retained position’s timestamp instead of the new fix. Every second hour the difference is “significant” and the clock jumps back to the time the device fell asleep.
The records are still sent every hour, but their timestamps drift further into the past: 2 h 02 min after 2 hours, 4 h 04 min after 4 hours, and over 40 hours after two days. The server shows them as old positions.
Steps to reproduce
- Configure Online Sleep, get a GNSS fix and let the device fall asleep in a place where it still gets a fix (e.g. by a window).
- Leave it still for a few hours.
- Compare the record timestamps with the time they arrive at the server.
Records from 21–23 Oct (device asleep since 21 Oct 23:58:38 UTC):
| Received (UTC) | Record time (UTC) | Offset |
| 22 Oct 01:58 | 22 Oct 01:58:39 | 0 |
| 22 Oct 03:58 | 22 Oct 01:56:27 | 2 h 02 min |
| 22 Oct 05:58 | 22 Oct 01:54:14 | 4 h 04 min |
| 23 Oct 07:58 | 22 Oct 01:32:44 | 30 h 26 min |
Logs (from the Dump)
[M:GPSD_PWU_CTRL]: PWU fix captured, holding
[M:GPSD_PWU_CTRL]: PWU wait hold elapsed, back to sleeping
[M:GPSD_PWU_CTRL]: PWU scheduled timer for 3600s (state 1)
[M:GPSD]: GNSS source changed to -> 5
[M:GPSD__TIME_SYNC]: Unsupported GNSS source for time sync
[M:GPSD__TIME_SYNC]: Time difference is significant, syncing time
[M:TIME]: Syncing to [1792627118]
[M:TIME]: Synchronizing with undefined source
1792627118 is 2026-10-21 23:58:38 UTC, the time of the fix the device fell asleep with. This sequence appears 17 times in two days, always with the same value. With 107:2 it also happened after PWU wait fix failure.
The Dump and the server-side log are available. I can send them privately.
Expected
The clock should be synced only from a fresh GNSS fix, NTP or the network, never from the retained position.
