I am having trouble finding where to enter the MQTT credentials to connect to my MQTT host (mqtt.emoovit.ai). I have tried to locate the section for MQTT credentials but unfortunately, I cannot find it. Could you please advise on how to configure the MQTT connection and where to enter the credentials?
It is not possible to use your own MQTT server. You can only use Azure and AWS MQTT services.
You may be able to adapt my custom FMC150 to InfluxDB2 Bridge quite easily to the FMC130 when using UDP and Codec 8 Extended. Maybe it even works out of the box.
Otherwise I can also recommend using Traccar to track your vehicles. It’s free and open source and has everything we need in out company.
