I have used a RUT240 for some years and have some knowledge of the Teltonika “thinking”.
The case now is that I have bought a tracker FTC134 to our boat. The use case is that besides the tracking I also want to use it as an Alarm.
For example:
On the DIN 1 I have connected a door magnetic contact and when the door is opened the input goes low and sends a SMS, “alarm”, to my phone. (Several other sensors shall also be connected, PIR, water level, eye sensor and so on)
The obvious thing is that this should not happen when I’m onboard. So therefore I need some sort of function to “arm/disarm”.
On the RUT240 there was a smart way with “Profiles” but this is not available on the tracker. Another way could have been using “Private/Business” mode but this don’t seems to be logic that can be used ?
So please advise how to proceed !
It should also be said that besides my “problem” it’s really a versatile product with a lot of opportunities !!
Have you look into the immobilization feature? You may select to authorize using beacon which you will carry the beacon with you. Upon beacon detection, it will deactivate the immobilization which it can control the DOUTs.
Sorry, but don’t really understand how this will solve my “problem” ?
Quote from the manual => “On the Teltonika FTC134 LTE Cat 1 tracker, the Immobilizer scenario allows you to prevent unauthorised vehicle operation by managing a digital output connected to an engine-starter cut-off relay.”
What I understand this will not stop, when “disarmed”, the FTC134 to send an SMS in the “door scenario” mentioned above ? or am I missing something ?
