/api/devices/.../command does not work properly
Calling https://rms.teltonika-networks.com/api/devices/..../command the reply is correct:
“success”: true,
“meta”: {
“channel”: “private-…”
How ever, the command never gets executed on the device TRB141, firmware TRB1_R_00.07.06.4
When calling the https://rms.teltonika-networks.com/status/channel/private-… endpoint, result is:
“success”: true,
“data”: {
“828906”: [
“status”: “pending”,
“type”: “text”,
“value”: “Sending custom command…”
“errorCode”: 65545,
“status”: “error”,
“type”: “text”,
“value”: “Timeout.”
Which endpoint is giving the “timeout”? How could I debug this more? The same command works on multiple other TRB141 devices.
