Alert from power supply switch?
Hi I have an RUTXR1, utilising two separate power supply inputs.
Wondering if the unit can tell if one supply is off (eg it has switched to the backup supply?) and can I interrogate the unit for this status, or define an alert? Modbus over IP would be ideal, but I don’t see that in the register table…
Basically I just want notice and logging that my main power supply is off - this would be an easy way if it was possible.
Thanks!
Unfortunately, it’s not possible to log which power supply is powering the device.
Our product, RUTXR1, doesn’t have any input/output (I/O) functionality. This means it doesn’t receive any information from the I/O pins in the power plug; they’re solely for powering. You can find more information here: RUTXR1 Powering Options.
Marijus
