I currently have an FMC125 device integrated with the RFID reader and card of Teltonika. Unfortunately, I’ve lost the RFID card but still have the reader intact.
Given a tight timeframe of about one week, I’m exploring my options:
Should I obtain a local RFID card to test with the existing reader, or
Would it be better to replace the reader and card set entirely?
Additionally, could you advise on key factors I should consider when purchasing if I go with either option?
Could you provide details on which RFID reader/card you have used with the device?
Furthermore, if you’ve tried a card from outside and it works, also the RFID reader can be able to detect the card ID, then there should be no issues with it because the main purpose is to detect the card ID.
If you’re purchasing any card from outside, please check that the frequency matches your existing RFID card. If the RFID has the same frequency, it should work properly.
