Access issue from LAN to WAN
I have already asked similar question, but not getting any replies. Just in short, I’m trying to ping a specific IP which is connected to the WAN side from LAN side. However, WAN side IP should not be able to access the LAN connected devices. Here is my topology. If anyone knows please let me know. I appreciate any help. Thank you.
e.
Hi!
Your WAN side is on the same subnet as your LAN side?
That’s not going to work.
Timelapse Admin
Actually your IP addressing scheme is a little confusing, there will be IP clash if the WAN and LAN are on the same IP subnet.
But if not you can set up a static route stating that all traffic to Spare PLC will be through the WAN.
Let me know if it helps.
Clive Pinto
