2nd Followup on OpenVPN DCO issue (disconnect after 1h)
this is the follow-up of follow-up
I tested “latest firmware 7.19” of a RUTX50 today. DCO is still not working
1138 Tue Nov 11 12:08:48 2025 daemon.notice openvpn(inst1_zzsznk)[23502]: dco_get_peer_stats: netlink reports object not found, ovpn-dco unloaded?
1139 Tue Nov 11 12:08:48 2025 daemon.notice openvpn(inst1_zzsznk)[23502]: dco_get_peer_stats: failed to send netlink message: No such file or directory (-2)
Full log is attached.
ovpn client file is vanilla from OpenVPN CloudConnexa server
log-dco-firmware-7.19.log.zip (4.9 KB)
We mentioned that the VPN connection should be more stable with firmware version 7.19; however, we did not state that DCO errors would be completely eliminated. In most cases, DCO-related issues are caused by network instability.
We appreciate your understanding.
all our Teltonika routers are stationary, but with a mobile internet connection. the internet connection is very reliable, we also use different network providers in Germany.
However, the issue here is that the TLS session goes stale after 3600 seconds, openvpn client (Teltonika Router) tries to re-establish and somehow fails but thinks it re-actived the session.
OpenVPN CloudConnexa does drop the TLS session.
As a result (as stated in earlier posts):
0:00 - 0:59 VPN works
1:01 - 2:02 VPN does not work
2:03- 3:03 VPN works
Or in other works: Routers are 50% not reachable through VPN.
I do not want to recommend other vendors or products, but I want to point out that INSYS ICOM managed to fix these DCO issues last summer and provided the patch in their official firmware 1 month later. (Yes, against the same server, same type of sim cards and network provider)
Thank you for the clarification. To investigate the issue further, we will need to review your troubleshoot file. I have sent a form to the email address you used to register on the community forum. Once you complete the form, we will contact you privately.
When filling out the form, please use ticket ID “16364”.
