Has anyone had success with 1nce SIMs in the UK. I know I’ve coverage for both NB-IOT and LTE-M where I am but cannot get anything to connect with known good SIMs
Looking at 1nce converge map, UK should be working just fine. I’ll ask you to perform the following steps:
Make sure your device is running the latest firmware;
Make sure you have the correct APN set in the Network → Interfaces → General → mob1s1a1 (SIM1) or mob1s2a1 (SIM2);
Please navigate to Status → Network → Mobile, take a screenshot and attach it to your next message;
Log into the device via CLI, and run the following command:
gsmctl -A 'AT+CEER'
Paste the output in the next comment.
- Finally, please navigate to System → Administration → Troubleshoot, open the System logs and copy the past few minutes of the logs. Paste them into a file sharing service, or if the forum allows you, your next comment.
Make sure to remove any sensitive information from the logs and screenshots!
